mach 2 r134 temps question
  • Thread starter Thread starter welshtom
  • Start date Start date
W
welshtom
Guest
What temps to the r134 machs get down to?
Would it be any good on a dual core X2?
Tom
It should be fine mate. With a high overclock it MAY hit + figures but i dunno, been a while since I used one of them.
Also a Dual Core X2???!?!! As apposed to a Single Core one :p
Boardy
well if i'd said dualcore you would ask if it was intel or amd.
i though that was the best way :p now shhhh
So what kinda temps do they register on the evap?
can get one for 180 ish, that a good price?
Tom
a 134 mach will be fine - yes plus temps under load (both cores 100%) are likely, but this is not bad for the mach unit.
For instance an x2 4800 @ 3100mhz fully loaded at 1.6v runs +6 degrees, if you push the CPU higher (in terms of volts) that number grows for few mhz more it's not worth it.
£180 is a great price, £250 is the going rate for a 134 Mach2.
Mav
EDIT: Sorry put correct data in now
thanks mav :). waited for you to come here hehe. you werent on msn otherwise i would have asked you there
yeah that's quite a good price really.
For that, you can afford to look at upgrading it at a later date and not break the bank.
Should hold the heatload of an X2 ok, likely not for best OC's or best phase temps, but still give you a good result :)
Gray
The early mach2 134a units get the best results from a 507 regas like mav's old unit because they have shorter cap tube than the gt:D
Dont tempt me now :p
Havent got any money as it is, prob end up selling this next week
Well, she pulled down to -59 on the LCD in a very cold room though.
prob be a week before i get it on my X2. Need to find a matchign Lian li now
Tom
