Blade Runner
Anyone installed a m.2 SSD directly on to a X99 Asus motherboard? (not using a PCI-E card; the fit direct to the mobo type fitting)
If so, what do you think? Is it much faster than a normally connected SSD? In practical terms, not just on a benchmark test?
P.S. I am sure I read somewhere, but cant find the article again, that you could not use the m.2 on the mobo as a boot drive. Have I imagined this :huh: or is it just some types of m.2 SSD that cant be used in that way?
