i was thinking about it and i am using at the moment a 56" Samsung HDTV 1080P in my living room for all my console gaming (PS3/Xbox360/Wii) and computer movies and surfing but it is not very comfortable for computer gaming and the res is not as high as i can get on a computer monitor (or at least not to my knowledge) as well as the fact that the smallest 1080P i found from Samsung is a 40" which will be too big for my Desktop so...
P.S. I'm also willing to pay less obviously this is just the max
you will see I'm building a new computer and i actually asked the same question there (can a single 8800 Ultra handle a high res 30" monitor) so.. if you can answer that i will appreciate that very much thank you
If it`s purely desktop, go for a Dell 24". (or 27" if available)
Samsung 32"+ are marvellous, and great TV screens, but they can`t match the color def of the Dell screens imo. I got one under the other atm, and u can tell when u do a multiview thing.
EDIT: Or smash the piggy bank and get an Apple Cinema screen - total droolness.
well i already have a Samsung 24" so i will stay with it for my new rig and once the 9900 GPU will be out along with the new Nvidia Chipset i will look into upgrading to a bigger screen thanks for all the help
OK 8 series cards do support high res up to 1920 x 1080 which is basically 1080p this is from experience also
if your screen is less then 42" then you will not notice the difference between a 1080p screen and a 1080i screen therefore i would say go for a 32" screen i think thats just right and bigger as i had a 37" it isnt very comfortable and it will feel like your going blind when the screen goes white (like in CSS when a flash bang is thrown )
