The news about Gene Maximus IV mean i can start working on my rig again quite soon.
I use Lian Li V354 case and in order to get a proper air flow I will have to get rid of as much cabling as I can.
I was thinking about just customizing my HX850 but longer i think about it, more I am keen to get look for new power supply which would fit my build better.
I will be running heavily overclocked 2500k and overclocked gtx570. In the future i will probably add another 570 if I feel that 1 is not enough, so power wise I am looking for something around 800-850watt to be on the safe side.
Ideally the PSU would have a fan at the rear, at this moment with my HX850 I have a choice of either exhaust into my GPU or wall of the case. Not the great choice here. If I won't find anything with rear fan I might consider to customize the case with a small side window just for the PSU fan but I would like to avoid it.
It would be nice if it was kept in black/red scheme to match with other hardware.
It can be modular or non, doesn't matter really since I have to suit the cables to fit.
Any suggestions are appreciated.
Cheers.
Cheers.
