Looking for 480mm rads
Deceit
Member
Would anyone be able to recommend decent 480mm rads and a good place to buy them bar specialtech as would prefer not to get them there.
For the rads budget isnt a problem. I'm going to be picking up three of them and would pay extra if could get better rads that would perform well of quieter fans. I would have a preference to get these as they push a decent amount of air and are quiet:
http://www.specialtech.co.uk/spshop...d-LED-Case-Fan--R4-L2R-20AR-R1-pid-12105.html.
I plan on getting 16 of them, 8 for the top rad and 4 on each of the two bottom rads.
your link isnt working and i think he said he didn't want to use specialtech all though we don't know the reason why as specialtech are one of the Top UK suppliers of water cooling parts and there back up support is second to none.
aye its true they sorted out a RMA for me in 3 days
day 1 i send it back
day 2 they test it and send out replacement pumo
day 3 royal mail special delivery before 9AM and its inside my pc
Yea sorry I put a dot at the end of the link by mistake, fixed now.
I would just prefer not to use them as had issues with both my orders from them (that didnt bother me as they eventually sorted them and issues can happen with orders) but after that they informed me would give me some fittings as an apology or a refund of delivery costs for the second order for this.
After a few months of waiting no reply and ignored my messages. I held off my last order as I had planned to save them the cost of postage where they could just put them in with them. You can probably see my pc is still missing its drive bay res and 47mm rad along with other fittings I wanted which I had planned to get from them which I was waiting to order.
Even if they got back to me and simply stated i'm sorry but I taught I could give you the fittings but have been told I cannot I would have been 100% happy with that. It was the fact it was offered then I was ignored was what pissed me off.
3x 480Rads ? what are you cooling ? a 480x60mm rad would basically be able to cool a CPU and 2 GPU's with ease.. all overclocked also..
Good fans are the key to a good cooling Rad and the GT AP-15 are the best imo.
I'm planning on cooling 3 6970's, 2 xeon's and an sr-2 hopefully with very quiet fans. I need it to be quiet as if work from home could be stuck sitting beside it for 10hours a day as would run esx server on one of the drives i'm going to put in it so can have about 50vm's on it.
Ow ok
Wouldn't you just be best getting a 940 then an have it outside the case that way you can have it on the otherside of the room with quick disconnects
I would just prefer not to use them as had issues with both my orders from them (that didnt bother me ect ect
ah that sound like you may have caught them at a bissy time. Have you ever contacted ayd or Steve directly or phoned them ...
Its a shame cos mistakes do happen and ive found them to be good with customer's when some thing goes wrong. Looks or sounds like this one passed then
Ayd is the one that hasnt got back to me and offered it to me, I generally just email being from ireland but maybe I should have at the time.
Ow ok
I wont be dissconnecting it though. I got such a big case so everything will fit inside easily and if have to move it its much handier this way.
Dear lord that is a powerhouse of a rig
Posted again as multiqutoe is failing hard for me.
I dont mind Sptech,its just there prices are sometimes overboard(postage mainly is a joke).
O/T:You finished testing your blue pearl yet Mayhem? I wantz it!
