lol vista available for every one now
Do you know if its got the same MD5 checksum (aka is it the same file as I downloaded yesterday from your post?)
Ben
Exactly the same as XP, but with say beta 2 of office 2007 you get some extra features.
Don't ask me what they are cos vista is pants.
name='stocky' said:
How does Vista behave with XP applications? Will it work with my MS Office?
most will work fine, but if you are having problems you just need to right click on the icon of the app you want to run and then click compatibility then just click run this program for windows XP, this will then make it work for windows XP apps.
