sfelock
Alright, so I've contacted Logitech's infamous customer support only to get the famous "we're too busy to get to you in a timely manner" reply. Thus I am bringing my issue to you guys in hopes someone may have a easy fix.
Lately I've noticed the FFB on my G27 become stuck. It will work fine for a bit, then all of a sudden, when it tries to center, it will shudder, stutter, and make a horrible noise. There seem to be no rhyme or reason to when or why, and it occurs in every game I play. Only way to fix it, and a temporary fix at that, is to unplug the wheel, let it set for 10-15 seconds, then plug it back in. This can get very inconvenient and would cause issue in multiplayer type races, therefore I've had to avoid them, or deal with the FFB issue. Also to note, when it it doing this, the wheel operates normal aside from this sticking, which more or less causes me to have to fight it back to center instead of it centering itself. I have already checked that all applicable software and firmware is up to date. And as noted before, I have already submitted a support ticket with logitech, but who knows how long it will take them to get to me.
Thanks in advance for any help you guys provide.
Cheers.
Cheers.
