hi all. first post here. saw some good oc videos on OC3DTV on you tube and thought i would join.
does increasing LLC just keep the vcore closer to what it's set at? i have an i5-4670k i am running at 4.5ghz. running occt and i keep seeing the vcore fluctuate from 1.2 to 1.16.
i have vcore set to normal, offset at +.066 and LLC at medium. should i be seeing these fluctuations?
using a gigabyte Z87X-D3H
thanks for the help
thanks for the help
