I finally started working on making my rig look respectable again.
The pc's components are:
i7 5820k
32gb ddr4 2400mhz gskill
Msi X99 sli plus motherboard
Msi 290x
Ax 1200 watt psu
Little Devil V10
500gb Samsung 850
4tb Hitachi
4tb external Drive
3 * 1920*1200 Hanns g monitors. They will be replaced next by 3 * 1920 * 1080 borderless ips monitors.
It started off in a Little Devil V 8 case and looked like these at various stages:
I then started to move to a 5820k from a 3820 based rig
After that I wanted to move to the V10 to start off in a full black rig and eventually move to blue look with the corsair fans.
I still need to do a lot of cable management and other bits before I am happy to say its finished.
I also finally made sure the full rig is using crystal link rather than soft tubing out the back.
This mess will be fixed when I learn how to braid cables. I am just waiting for mdpc-x to take orders again.
I will use the phase change kit for other projects in the future:
This is the difference in size of the two cases:
The V10 is taller and wider than the V8
i7 5820k
Msi 290x
Ax 1200 watt psu
Little Devil V10
500gb Samsung 850
4tb Hitachi
4tb external Drive
