Liquid NH-D14
T.A.K
I wad looking at the Gigabyte P67A-UD7 and was really displeased with the PCIE 16x slots were located. Then I thought about running 1 gpu on 8x but then there is no point in buying the UD7 instead of a cheaper board.Thusly I decided water cooling would work just fine in the tight config.
So what I was planning on doing is mounting a thick 240 rad externaly then cooling two GTX 570's off. Then leaving the CPU to the NH-D14.
Do you think this would work or crash in flames?
Ignore this or delete it. Stupid iPhone dropped me in the wrong forum section. Wanted it in new build advice.
It should work, and a mod will probably move this to the appropriate section. But I would try to mount the rad internally, since in my opinion, external radiators look like a cheap bolt on job.
Yeah, especially if it is mounted over the 120mm exaust. The D14 will be feeding it hot air.
