Lightning switch
Dawelio
Active member
Hello guys,
I was wondering if you know any switch, where you can control the LED light on an BitFenix Spectre Pro 200mm?... as they come with an wire which you connect to the fan and you can then turn the LED on and off.
If you know any custom, aftermarket switch or so, where you can mod into the case on a Corsair 250D?
Thank you,
Chrazey
Hello guys,
Thank you,
Chrazey
Wouldn't a basic on/off 12v switch do the trick?
just need some basic soldering skills and you're good to go.
Thanks for the reply, that's a good tip!... where can I get hold of one of those, are they called anything specific?
You don't happen to know any soft push buttons though?, like a power putton on a PC, as the start button on the Corsair Graphite 380T for example?...
Toggle switch. Most hardware stores/electrical supply stores carry them. Radio Shacks do as well if you have that sort of thing in your area.
Aye, they come in a variety of models. There are also models with LEDS on them:
As hmmblah said, just head on down to the closest store and check out the different models. I'm sure they got something to suit your needs mate :)
Thanks for that and I have looked and found 2 that are similar to the ones you have in the picture.
Although, I do have a black and blue themed build and really got my eyes for that button in your picture, with blue light on it.
Do you know where I can hold of that one?...
Well I dunno where you live so I can't really point in the right direction. In the nordic countries we have a great chain that sells these kinds of things called Biltema, I think Halford's is something similar in the UK.
I actually live in Sweden, so I know of Biltema as you mentioned. Although, I can't seem to find any good there... only ones I find are for cars, not sure if those are the same as the ones you posted.
Where did you find that picture, Google I assume?... As I really, haha, really got an eye for that blue switch in your picture now lol :P
Ha! :D ... well thank you for that link and it looks very promising I must say.
So thank you fellow neighbour! :p
