Lian Li PC75 + 120.3 + Mach2 ST in Lina Li kit
Ferret
Will I have any problems fitting together this lot? I have the urge to spend some cash!
LMAO @ your sig.
You wont have any major issues, although the PC75 sits slightly uneven on the mach II due to the size difference. It looks great from the front however.
Cheers Phil that’s what I wanted to hear, I remember your pic when you put a PC75 on top and knew there would be an overhang so its no issue.
I've got the same but with an LS, there is a bit of overhang at the back but it isn't really noticeable, unless you like having the back of your case on view instead of the front :p
Looks like it is going ahead (well when the PC75 and 120.3 appears), I have purchased a Belkin Blue light switch thingy and a 2x16 Blue/White LCD that I plan to wire up to the printer port (as my ST doesn't support LCDs).
In fact the LCD is £35 and looks very high quality, should be interesting to see how it all ends up :)
yeah sorry about the delay matey, it all went out today for you - case, rad and shrouds etc. You should already have the tubing and other bits you ordered. :)
LoL it's no problem :) I have the kit, tubing and drive covers already!
Like I said a few days wont kill me :)
Also I nearly had a fit when I saw both sides of the kit had massive scratches in them, until I realised that was the inside lol.
