Hello there guys
 Just wanted to share some pictures of my new PC-V600FB and a little review and some thoughts I have about the case.
The V600F is a Lian Li mATX chassis and it comes with some nice innovative features and a pretty design. The case comes in 4 color options, silver, black, red and full black. There is a nice quality feeling to this case which is to be expected from all Lian Li chassis.
Front
Sidepanel
Top you can't fit a AIO cooler here because it will then hit the motherboard. Its a tight case
Front panel (on top)
Bottom with 120mm dust filter for the powersupply and 4 rubberfeet.
It comes with 2x 120mm fans in the front that has blue LED and 1x 140mm in the roof. I personally don't like LED fans in a case, I think it looks much more elegant without the flashing blue LED's so I swapped them with a all black fan from Cooler Master. All 3 fans comes with dustfilters that is very easily removed by twisting it clockwise.
This mATX chassis has 2 sepperate harddrive bays which support up to 2x 2.5" drives and 5x 3.5" drives. I'm only using 1x 2.5" SSD and 2x 2.5" HDD's, now these harddrive cages is originally hotswap bays, but the hotswap does not support 2.5" harddrives, only 3.5" HDDs. To make my setup work as I would I had to screw out the hotswap PCB behind the harddrive cage (5 screws).
Cablemanagement on this case is not to bad, I use a non-modular PSU with 500 watts from Silver Power and I managed to get some decent looking cablemanagement after spending a fair amount of time on the cable routing. Honestly I thought it would be much worse than it turned out at last with the cable management, because this case does not come with more than one tight hole to push your cables through (that's what she said) and hide them away. The trick is to hide the cables you don't use at the bottom of the harddrive cage if possible, that helped me out a lot.
There is 15mm cleareance behind the motherboard tray.
You can have aircooling solutions up to about 155mm in height.
Lian Li was generous to put a hole in their case. Can you see it?
Overall I think this is a very nice case for an mATX build, and I think its the best looking mATX case on the market today.
Whats inside this build:
Intel Core i5 3450 cpu
Kingston HyperX Genesis 2x4GB 1600MHz ram
MSI B75MA-P45 mATX motherboard
AMD Radeon HD 7870 GHz Edition from XFX
CD/DVD Drive
2x 250GB 2.5" HDDs
1x Intel 80GB SSD
This is my first review, and I understand that it's not a very good one, but I did it for you guys, and I hope you liked it.
Front
Sidepanel
CD/DVD Drive
2x 250GB 2.5" HDDs
1x Intel 80GB SSD
