Lian-Li Launches PC-B70 & B71 Full Tower Chassis
Find myself going all gooey over the insides of those cases.
Have to admit tho, don't like the look of the front fan section.
name='cybermaniac' said:
whats different between the B71 and the A71?
Lazy cyberman! :p
The PC-B71 is different via the lower part of the front bezel which has an integrated HDD Hot swappable SATA cage with a front facing securely lockable door.
I do like Lian Li, and Kelly Hu too.
name='tinytomlogan' said:
I love lian li's, but this idea of 50 cases based on 1 chassis is getting boring now
Agreed. These ones look like they've got the same tinfoil thickness panels as a lot of their other recent cases too.
Lian Li need to make a case that:
- has the same thickness aluminium (1.5mm iirc) as the V series.
- is anodised inside and out so no need for powdercoating internals black
- uses no/few rivets. screws are a modders best friend imo.
- has optional extras such as pre-cut roofs for thermo/normal rads
They do have points 2 and 3 covered pretty much (you can get 15mm spacing triple fan roof panels for the A70/71, which should fit the newer cases based on the same chassis)..... and if they covered point 2 what would Tommy boy do. :P
I'll admit it IS a little boring seeing the same internals again and again, but lets face it, what other cases can so easily accommodate such a large amount of radiator area? :D
