Lian Li A10B
weihk
Lian Li A10B
Enermax 720w infinity
C2D 6300 - swiftech apogee
OCZ 2GB PC8500 SLi edition (D9GMH)
2900xt - swiftech MCW60
thermalright HR-09S on mosfets
swiftech MCW30 on NB
Enzotech low profile copper heatsink on SB
DDC pump
10/8 Black hose
10/8 compression fittings
micro-res
PA120.3
BigNG
its not really done....yet.....still have sound proofing havent done....
the last WC part was fitted last sat, and has since been under stress test.
currently have 2 Bios profile, 1 for OC, the other for normal use(stock speed and set for lowest temp, use when im not gaming)
well....thats it for now, i'll tidy it up a bit more.....SOON.....LOL
will update again when i can bebother to do the rest.....LOL
U gotta love LL cases.
I`d seriously consider not using the top fan there.
(Don`t let Frag see the wires !!)
hehe
You suffer from my affliction too - inability to manage cables! :D
I was going to buy that case but my cash flow is restricted atm... How are you finding it?
Looks pretty good, though definitely could do with some tidying. I still think my wire management is the worst here on the forums though :D (I really need to take care of that this summer >.>)
:eek:
Where did you get that 8-Pin extender mate? Gonna need one of them soon...
Nice build, but wheres your rad :eh:
hehe
yup, LL case are da best! WOOT! lol
i did think about taking off the top fan, but with all a 2900xt inside is a bit risky.....lol
cable management? whats that?:D :D
and im getting on very well with this case, its not too small, have plenty of room for most things, i can pretty much think this is one of the best case around for whatever build people is going for.
also build the WC loop to be very flexible, ie, i can slide the mobo tray out, together with mobo/blocks/pump/res/raditator still attached, good eh?
heh, you havent seen my old P180 build, or eles you'll give up the crown for the worst cable management on OC3D!
that old build of mine....if the side panel taken off, you'll face another 'panel' of wires/cables/hose, have to move all that out the way then you'll see the mobo! LOL:D :D :D
name='Ham' said:
:eek:
i bought the 8pin extension from eBay, the seller was in USA tho, that was about a year ago, cost about 7quid with p&p.
quick search showed this
http://cgi.ebay.co.uk/PSU-Extension...n-F-AKASA_W0QQitemZ160132274582QQcmdZViewItem
good luck!
