Lets make it better......
tylerdustin2008
Well heres a simple mod.... Nothing fancy.
Well I bought this case from a friend for $10, was a good deal for a case. There was a big problem with the case....And that was the cooling, 92mm exhaust and no intake.
I did not take pics form the start sorry....
First thing that I did was to remove the internal 3.5" bays.... Well that sounds easier that it actually was. I had to take the case completely apart, rivets in the stupidest places.
Next I drilled the 120mm front intake, that was easy.
Then I cut a hole in the front bezel and started applying my bondo.
Now I am letting the bondo cure, going to get some sand paper, primer and paint tomorrow.
Here are the pics.....
If you have any ideas for me let me know. I really don't know what else to do to the case.
Tyler
