Dawelio
Active member
Hey guys,
Not sure if this is the correct place to post in, but if it's the wrong section, please move it to the correct one.
I was wondering if anyone know any way (other than molding) to change this light to a blue one. If there's like a plastic or rubber cover you can slide over the light itself to change the light. As spray painting it would quite a pain to be honest... plus, I don't think that Plastidip is that resistance to heat, which this light most likely will output a little bit.
But as I said, if anyone knows any way, please share!
Thanks!,
Chrazey
Thanks!,
Chrazey
