Laptop HDD
purple_pizza
This maybe a repeated post, if it is plz point me in the right direction?
I am looking for a way to access my old laptop HDD on my current desktop.
The HDD in question is a "Seagate Momentus 5400.2, AT disc drive"
Currently it has a 22 single pin IDE attachment.
Any help would be much apprecitated
regards
Pizza
http://www.maplin.co.uk/Module.aspx?ModuleNo=36945
Something like this or a docking solution may work.
http://www.aria.co.uk/Products/Components/Drive+Enclosures/External+(For+SATA+Drive)/Sharkoon+QuickPort+Combo+IDE+and+SATA+Docking+Station?productId=39471
Be wary though, I used one and it promptly melted! The maplin type one was cheap and nasty.
Was fortunate enough to save the drive though.
I used to use one of the top ones all the time. Well, not that specific one but one that looked identical.
Back in the Win98 days I had a laptop with no cdr. So I would part install Win98 on the drive (in my pc) and then when it did the restart before detecting hardware I would simply stop it, go into a dos prompt and put all the cabinet files on
