AverageNinja
Average Penis Too
Hey guys,
So as some of you may or may not know my laptop's HDD died recently. I grabbed the drive out of my PS3 as a temporary solution and installed Windows 8.1 on it. It seems to be working fine, though there's one (annoying) problem.
When I'm playing games (mainly Dark Souls at the moment), blue screens will occur. It's not that it happens after a set time, sometimes it'll happen in 10 minutes, sometimes after a few hours. Needless to say it's quite frustrating.
I think I already know what the problem is: the Intel Onboard GPU. The dump says the following:
Dump File: 050515-24671-01.dmp
Bug Check String: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug check code: 0x000000d1
Parameter 1: 00000000`00000028
Parameter 2: 00000000`00000002
Parameter 3: 00000000`00000000
Parameter 4: fffff801`386a5c47
Caused by driver: igdkmd64.sys
Caused by adress: igdkmd64.sys+62c47
File description: Intel Graphics Kernel Mode Driver
Product name: Intel HD Graphics Drivers for Windows 8(R)
Company: Intel Corporation
File version: 10.18.10.3308
Processor: x64
Crash adress: ntoskrnl.exe+153fa0
Full path: C:\Windows\Minidump\050515-24671-01.dmp
Processor count: 2
Major version: 15
Minor version: 9600
Now before you suggest me that I should disable the onboard graphics, I tried. That's the main problem. The system sees my Intel GPU as the main display adapter. When I disable it, at first my second monitor stops working. Then when I restart, the second monitor is the only thing that'll work. At 4 possible resolutions. One thing I haven't tried yet is to reinstall the Nvidia drivers after disabling the Intel GPU, so I'll try that right now.
Suggestions on what to do are always welcome
Cheers!
AverageNinja
Processor: x64
Processor count: 2
Major version: 15
Minor version: 9600
Cheers!
AverageNinja
