G General_Chris New member Jan 11, 2009 #1 hey guys my kingston ram 2x1GB doesnt want to OC past 210 MHz its not ValueRAM what i know off
N noobieocer New member Jan 11, 2009 #2 what is its stock speeds and timmings? try loosening the timmings, or up voltage 0.1v-0.2v and see would it go any faster i am not responsible if this kills your ram, just some advice. the timmings should be safe to play with but voltages can kill your ram
Z zak4994 New member Jan 11, 2009 #3 Probably because it running at 533mhz DDR/DDR2 (I get mixed up ) Of which half of that will be how much you can go up to.
G General_Chris New member Jan 11, 2009 #4 its default speed is 200 mhz its now running at 177 mhz due to cpu or i cant get it to 2.66 GHz
G GavX New member Jan 13, 2009 #5 Just remember with RAM you basically double the speed, so it would be 400Mhz effective, but since I assume it is DDR don't expect great overclocks. 420Mhz does seem a bit poop though, as said, more voltage, loosen timings a touch
