K8N Neo2 Platinum Problems
fatty
Ok I have recently purchased and set up one of these mobo's and it does have a few issues so I thought I would start a topic so peeps could share their problems
Firstly the temp issues the motherboard does not show the correct temps when my mach 2 is showing -49 the mobo is showing -122 then it will switch to +122 and try to shut down the degrees are in Celcious .
Secondly on every second boot either via reset or via windows the motherboard will hang on the bios screen or before the bios screen ie blank screen and wont do anything then you either have to reset the cmos or stop and start the pc to get it to boot on the D bracket when this happens the LED's show cpu initialize code or floppy initialize code???
I am hoping that with a bios upgrade these issues will be fixed I have downloaded the latest bios to no avail
On the upside the mobo runs stable at 260 fsb with only 2.7 volts going through my ocz ram I am going to try higher fsb soon but I am still running my fx53 in so I dont want to trash it just yet
This is a great mobo and I do recomend it as all the locks work it will supply up to 1.85 volts to your cpu also 2.85 to your ram
Hope this helps other peeps
Cheers
Sounds a little like my problems with my MSI K8T Neo. Couldn't get the thing to work at all so upgraded to Asus K8VSE, havn't looked back since. (Until this SK8V FX53 rig :p)
Boardy
