Just seen these what do you think
sacha35
OCZ EL PC5000 Platinum DFI nF4 Special Edition (DDR625)
Brand new release from OCZ:
OCZ EL PC5000 Platinum Edition, Dual Channel for DFI nF4 Motherboards
The latest release in OCZ's Extreme memory category - the PC5000 Platinum Edition rated CAS 3-4-4-10. Reaching speeds of up to 625MHz. Specifically designed for the DFI nF4 motherboard range.
Available as dual channel optimised kits in sizes 512Mb and 1Gb kits. Tested on ASUS P4C800-E Deluxe.
OCZ Platinum Edition PC-5000 memory has been designed for ultra-high speed operation on DFI nF4 motherboards. Due to OCZ’s proprietary Enhanced Latency Technology, the PC-5000 Platinum DFI nF4 Special series is able to reach latencies as low as CL 3-4-4-10!
All OCZ DDR-625 products are 100% hand-tested to ensure compliance with stringent quality standards. Furthermore, every PC-5000 1GB Dual Channel Kit is confirmed as a matched pair to ensure flawless performance on DFI nF4 motherboards. In addition, each OCZ PC-5000 Platinum Edition module also comes with a high quality copper heatspreader with a platinum mirrored finish and ULN2 (Ultra Low Noise) Technology to maximize stability and performance.
OCZ PC-5000 Platinum DFI nF4 series modules are the very best high speed DDR memory available on the market today and offer innovative features that increase performance while providing unsurpassed stability. OCZ Platinum Edition memory modules are rated to handle up to 3.0V without invalidating the OCZ Lifetime Warranty so that performance enthusiasts can tweak their systems without worry.
In stock now - delivered in retail packaging!
Specifications:
1Gb DDR625 PC5000 Dual Channel kit = 2x 512Mb modules
625MHz DDR625 (PC5000)
CL 3-4-4-10
Specially designed for use with DFI nF4 motherboards
Dual Channel Optimized Kit
Unbuffered
Mirrored Platinum Copper Heatspreader
Lifetime Warranty
2.85 Volts
184 Pin DIMM
EVP® (Extended Voltage Protection)*
ULN2 (Ultra Low Noise)**
Retail packed
OCZ product codes: 1GB kit OCZ6251024ELDCPE-K
Further information
