Ok so I thought i'd do it as at my normal settings I experience a slight vdroop but when I cracked it up earlier I got a massive vdroop. Will show all in a second.
The first resistor I tried was what this site said:
http://www.vr-zone.com/index.php?i=4450&s=12
It didn't seem to do anything so I tried the resistor shown on this site:
http://www.xtremesystems.org/forums/showthread.php?t=127528&page=3
The results were great! I checked after doing it lightly once and still nothing so I shut down, unplugged and tried a little harder this time.. It had decreased it ever so slightly but not much. Once more, shut down, unplugged and made sure I covered it but not really thickly as I didn't want to over do it.
Results:
The Vcore set in the BIOS is 1.4375v
Pre mod:
Idle through CPU-Z = 1.440 Load through CPU-Z = 1.360 / 1.344
Idle through SpeedFan = 1.420 Load through SpeedFan = 1.360
After mod:
Idle through CPU-Z = 1.456 Load through CPU-Z = 1.440
Idle through SpeedFan = 1.460 Load through SpeedFan = 1.440
Ok so it bumped the idle voltage up a little but I can remedy that by just taking it down a notch in the BIOS.. It also means I can probably take it down a couple more notches due to there being very little Vdroop when under load.
I'm going to test some other settings I tried earlier that kind of pushed me to do the mod anyway.. I cranked it up to the following:
400mhz x 9 = 3600mhz @ 1.500v in the BIOS
FSB @ 1600mhz with RAM at 800mhz to get the ratio of 1:1.
Timings of 4-4-4-15-2T
Voltage through CPU-Z were fluctuating between 1.472 and 1.238 which is crazy... It even dropped low enough once to make the thing blue screen me and restart.
I'll go test the droop on these settings now.
Results:
Pre mod:
After mod:
