T
Thickbrit
Guest
Well,i couldn't work out how to shrink images small enough to upload,so i learnt a bit of html,here ya go....http://www.overclockpassion.com/ ,feedback please on my first attempt.
Thickbrit, I'll say thanx now before I start cos I am in same position with IC7MAx3 and WD Raptors!name='Thickbrit' said:Set "bootable add in device" to "on-chip sata raid".If you want to boot from the intel,move "bootable add in device" to top of "hard disk boot priority",using the + key.In "integrated peripherals"--->"on chip ide devices",set"on chip sata mode" to "raid","sata raid rom " to "enabled" and "on chip serial ata" to enhanced.Set boot order to floppy,cd,harddrive.Reboot ,hit control+i straight away,to setup the raid,exit,boot to cd,start xp install,hit & hold f6 at the prompt(be quick),install intel drivers from floppy,following the prompts,continue install.Good luck,feel free to ask again.![]()
I aint seen boot so often in a post since I mistakenly typed S & M instead of M & SThickbrit said:Yes,before you set up the raid, your h/d's on ports 1+2 appear as individual drives in "hard disc boot priority" (along with bootable add-in device and any other h/d's).After you create the raid you will only see bootable add-in device and any other h/d's in "hard disc boot priority".Your raid is your bootable add-in device (because you set "bootable add-in device" to "on-chip sata raid" and hence, you move it to the top of "hard disc boot priority" to boot from it.I dont know why you couldn't install IAAR,but I've run with and without it,and couldn't tell the difference.If i'm confusing anyone,maybe this is clearer...
http://www.gatortravels.com/abit_ic7/ich5r_raid_setup.html
hi again got the intel chipset drivers working how can i get 1 raptor drive on the silcom port working port 3 thx aagin.
