It's old, and more entry level kit even for it's day, it was not built to handle games.
Coolermaster RC-330 Elite mid-tower case
Before you look inside, this case has no cable management bits and I tried what I could to keep things tidy. And it is a rainbow of mismatched colours in the box.
Mobo: Gigabyte 965P-S3 Rev3.3
CPU: Intel Core 2 Duo E6300 1.86GHz OC'ed to 2.8GHz, + Noctua U12P SE2 heatsink
RAM: 2x 1GB DDR2-800 OCZ Vista Value, 2x 2GB DDR2-800 Corsair XMS2
PSU: Antec NeoPower HE 500W
GPU: HIS Radeon X1650 (a what?) 256MB
HDD: 2TB Western Digital Green, 750GB Seagate Barracuda 7200
ODD: Pioneer DVR-212
Let me just say this first, I got the Noctua bling before I ever heard of OC3D or tinytomlogan raving reviews of Noctua. I got the giant heatsink because the round Intel stock cooler is pathetic; on a summer's afternoon, in stock settings, the CPU will actually overheat under load.
I could not twist the USB, and power-reset-HDD cables any farther to stuff behind the motherboard or else they will start discounting from the tension.
I have since rerouted the wires connected to the CPU fan header, and stuffed them behind the fat heatsink.
And yes the Seagate HDD is not connected, I butchered a FreeAgent external hard drive because that thing unreliable in its aluminium and plastic 'oven' casing. I don't have enough SATA data cables at the moment.
I have also since sealing off the open PCI slots with a combination of tape and paper card since the case's PCI covers are removable but not replaceable. I decided to seal them because I only have one exhaust fan and the two fans on the CPU heatsink is creating quite the negative pressure system.
This space will be occupied by a Coolermaster 4-in-3 module, to add to that a 120mm fan will be mounted in the lower front section to hopefully reverse my rig into a positive pressure system to keep the dust out.
No space to coil and stuff cables , the cables that need to 'shorten' did not have enough stretch to anchor into the space between the 3.5" rack and the right case wall.
