Joining 98860
Excalabur50
Well-known member
G'day Everyone
Decided to join you great people with some folding, I may not do heaps but figured some is better than none i just hope i set everything up properly LOL. Anyway great to be a part of this fantastic team!
I may be a bit of a dope but where does this install to? I can't find it to restart it again.
There should be a folder, maybe on your desktop called FAH GPU Tracker V2 or it maybe in the location where you saved the zipped folder when you downloaded it. Check in your downloads folder or on your desktop
Ok so when you click it it says it wants to reinstall if you say no it looks like you need to reinput everything again.
You shouldn't need to re install it.
You need to search you system for the folder that has files and folders very similar to this:
Once found, drag it to desktop so its easier to find
I hope this helps
I hope this helps
Thanks again Dipzy just did a search and no such folder exists so I shall reinstall everything and hope it goes right this time
87 does seem reasonable. I was hitting 90, but I gave my card a good clean and temps stay around 80 now with the fans at 100%. What speed are your fans at when it hits 87. I'm assuming 100% or have you set a custom fan profile?
Everything is on auto mate from what I could tell the fan was at 70% at 4830 rpm it's the hottest its gotten today, the other two days it was at 85deg and my cpu gets to about 62deg on one of the cores which i think is pretty good for 100% load and today was a bit cooler weather wise just more humid around 85-90% so maybe that has something to do with it.
