Jammi's Rigs.
jammi
As I have a fair few ill post finished builds here.
First my main rig.
Current spec (images may not reflect the current spec but this is what its at now)
i5 2500k
P67 TUF
Corsair Dominator 1600Mhz 16GB
Corsair H70
2x 128GB M4 1x 128GB Kingston
2x XFX 6950 @ 6970 spec
Corsair AX750
Fractal R3
Thanks Brooksie.
Just finished this one last week, what you think?
-Family PC
A8-3850 @ 3.62Ghz
Gigabyte GA-A75M-UD2H
Mushkin Blackline Ridgeback 1866Mhz 8GB @ 1600Mhz 9-9-9-24
Be Quite! Dark Rock Pro
60GB Solid3 OCZ
Sapphire Ultimate 6670
NEC BD-Rom
Corsair AX750
Silverstone FT03B
Tried my had at a bit of braiding with the pwr, reset, hdd led and power led.
I've taken out the hot-swap hdd mount and the lower hdd mount. I plan to run the rear I/O cable's down the slot for the hot-swap drive and make a hole near the bottom power socket for all the cables to come out.
I REALLY like how well thought out your FT03 build is.
You can really tell you put the effort in. Simply gorgeous.
Nice rigs, the both of them! Was the first build made recently; if so, you should have waited for the new h80/h100.
My home network stuff and other rigs, custom server builds (well not the switchs) work in progress and photos were taken while rest of the rooms were getting connected up.
Modded the wall cabinet with 3 120mm 4000rpm fans.
Cisco 24port gigabit switch
3com 24port gigabit managed switch
Patch panel
Custom firewall running pfsense 2.0 (Atom D510 has IPMI, quad intel gigabit nic)
Custom webserver, MySQL server (Xeon E3-1220L, 2x 1TB 2.5" raid1, 32GB SSD, 16gb ECC)
CCTV box (E6600, 8 channel plus bunch of ip cams)
Few more pics of the two supermicro based rigs.
Custom webserver
Custom firewall
And last my main servers for personal and work.
Storage is spread over two servers, one main the other is just does backups really.
Server1 49TB
Dual L5630
Supermicro X8DTH-IF
Crucial 48GB buffered
Narco 20 bay case
Zalman ZM850-HP
2x Intel 320 40GB raid1 OS (Windows 2008r2, Hyper-V & WHS11)
2x Samsung 500GB 2.5" raid0 (Work/Temp drive)
Adaptec 31605
12x Samsung 2TB Eco (two raid 5 arrays)
Adaptec 51245
8x Samsung 2TB Eco (raid 5 with hotspare)
ext sas 4x Samsung 2TB Eco (raid 5, need to find a expander that works with this for more drives)
Server2 20TB
E3-1260L
Supermicro X9SCM-F
Crucial 16GB ECC
Supermicro SC835
Supermicro 920w 80+ platinum
Crucial M4 64GB OS (Windows 2008r2)
2x Samsung 2TB
LSI 8708elp
8x Samsung 2TB (raid 0+1, OS backups, important files)
Woooaaauuw,that is one big collection of expensive hardware
Would love to have your server1 with two x5690,for folding
Nice and tidy as all other rigs you have shown
There's some really nice kit there, I don't why I seem to be only able to see 2/3 of the photos posted.
Out of interest, what camera are you using? The photos are very clear, well lit, and expertly compositioned.
Think the Canon 5D MK2 for both the first rigs and Canon 7D for the rest of the pics.
I lolled really hard at that
Rough Price estimate for all that kit?! yer really nice gear man!
Including my main rig and all about 12k everything was put together over the last 5 months when I moved into my new place with the FT03 build being done last week.
