Hey guys, as some of you may remember I posted here a while ago with thoughts as to building an ITX rig based around the Prodigy. I've finally gotten some funds together and am beginning the build this week! The case arrives Wednesday
The specs are as follows:
Bitfenix Prodigy - Arctic White
i53570K
ASUS P8Z77-I Deluxe
8Gb DDR3 Mushkin Radioactive/Frostbyte (undecided - probably going to paint the heatsink white or blue anyway)
Silverstone Stryder Plus 600W PSU - fully modular (using short cable kit and probably rebraiding all the cables either blue or white)
MSI ATI Radeon HD7950OC (reference) - hopefully going to watercool later
Crucial M4 128Gb SSD
1Tb 2.5" HDD (undecided brand - probably cheapest
Corsair H100 (planning on painting/carbon wrapping the radiator and the Block/pump and possibly braiding or painting the tubes white or blue)
The colour scheme is going to be blue and white with touches of black. I'm thinking of putting a window on either side of the case - on one side the window will be in the shape of the Bitfenix logo (side where the hard drives will be mounted) and probably a more standard design on the other - however I'm thinking of just having the same design on both sides. For lighting I'm thinking of using blue and white EL wire where possible instead of LEDs (just for a change). I was also contemplating the manufacture of a heatshield/blanking plate for the motherboard - could easily have this laser cut as I personally hate the look of mobo PCBs - thoughts on the blanking plate?
So yeah, any thoughts on the spec list/build?
Also I had a few questions:
1) With regards to fans, I'd like to use the same model throughout the case where possible - the fans I want are the Bitfenix Spectre Pro ALL WHITES (going to put blue LEDs in) - I've heard that these fans aren't good when used with rads - why is that? and should I use different fans - could I not get away with these?
2) Do you guys have any tips or suggestions for the painting/braiding/modding of the components? ie: the H100 and RAM sinks; I'd be really appreciative of any advice you could give.
3) Should I forget about EL wire and just stick with LEDs?
4) I know it sounds stupid but would it be possible to cool the graphics card by modifying the bracket or something similar of a prebuilt loop? I've heard of the Antec Kuhler but I was thinking more along the lines of the H80/H100. I love the idea of a custom loop but I don't think that a loop for both the GPU and the CPU falls within my current budget - however, it may be an option in the future. However, I do like the look of the all in one systems.
i53570K
ASUS P8Z77-I Deluxe
