Itx build some help please
Rob_the_scot
Iv got the itx fever again :lol:
This is what I want in my system
i5 3450 (owned)
512gb ssd (owned)
Silverstone FT03 mini
Silverstone 450 strider gold rated moduler sfx
Gigabyte b75 itx
Mushkin Enhanced BlackLine Frostbyte 2x8gb 1600mhz (Video editing)
zotac gtx660 (non ti)
The only real 2 questions I have is will the psu be enough for the zotac gtx 660 Iv had a look and they said 600watts..surely that cant be rite :confused:
second question is the ram will I have to do any thing in the bios for mobo to see the ram speed?
That does seem overkill..
Pretty sure all non-stock RAM needs to be manually set in the BIOS.
Overkill as in ram??...I was told for video editing more the better the speeds I wasnt to sure about thought faster the better
RAM over 1333MHz shall have to be configured in the BIOS. It's not hard, you just turn 'XMP' on and it does it for you. You can also do it manually, but when you have XMP to do it all for you, there's really no point :)
