Ok since my PC had to be formatted after a virus I lost all my music on iTunes. My question is, is there any way I can connect my iPod and add songs without it removing all the songs I lost?
there is software available which can get musi form your ipod backto your computer, although it is third party and we wont be held responsible if you bugger up your ipod.
Umm also an option in iTunes is to not synch your ipod every time you plug it in. Then you just "select all" in the ipod folder in itunes and drag'n'drop it into your library.
