Issues building/linking OpenSSL on Win7 64bit and linking in VS2010
andrewmchugh
I was running a boost ssl project on linux which OpenSSL seems to be less of a ball ache. Since boost requires openssl to be installed, I tired to install it and then use an SSL example to test the installation.
I ran the following commands with VS2010 command prompt with the extracted OpenSSL source (most recent from openssl site) as the working directory.
Code:
perl Configure VC-WIN64A // no prefix so it just builds to /usr/local
ms\do_win64a
// not using the DLLs but I built them anyway.
nmake -f ms\ntdll.mak
nmake -f ms\ntdll.mak install
nmake -f ms\nt.mak
nmake -f ms\nt.mak install
It all builds without failing (or doesn't flag anything up) but the project fails to compile due to undefined symbols. I know it must be something with the way I built it. But I can see where I could have gone wrong since is so simple. I have deleted the src and build are tired repeating a few times but had no luck. I am literally pulling my hair out it has brought my project to a standstill.
Code:
1>OpenSSLCryptoSample.obj : error LNK2019: unresolved external symbol _EVP_CIPHER_CTX_cleanup referenced in function "bool __cdecl do_encrypt(char const *,unsigned char *,int *,unsigned char *,unsigned char *)" (?do_encrypt@@YA_NPBDPAEPAH11@Z)
1>OpenSSLCryptoSample.obj : error LNK2019: unresolved external symbol _EVP_EncryptFinal_ex referenced in function "bool __cdecl do_encrypt(char const *,unsigned char *,int *,unsigned char *,unsigned char *)" (?do_encrypt@@YA_NPBDPAEPAH11@Z)
1>OpenSSLCryptoSample.obj : error LNK2019: unresolved external symbol _EVP_EncryptUpdate referenced in function "bool __cdecl do_encrypt(char const *,unsigned char *,int *,unsigned char *,unsigned char *)" (?do_encrypt@@YA_NPBDPAEPAH11@Z)
1>OpenSSLCryptoSample.obj : error LNK2019: unresolved external symbol _EVP_EncryptInit_ex referenced in function "bool __cdecl do_encrypt(char const *,unsigned char *,int *,unsigned char *,unsigned char *)" (?do_encrypt@@YA_NPBDPAEPAH11@Z)
1>OpenSSLCryptoSample.obj : error LNK2019: unresolved external symbol _EVP_bf_cbc referenced in function "bool __cdecl do_encrypt(char const *,unsigned char *,int *,unsigned char *,unsigned char *)" (?do_encrypt@@YA_NPBDPAEPAH11@Z)
1>OpenSSLCryptoSample.obj : error LNK2019: unresolved external symbol _EVP_CIPHER_CTX_init referenced in function "bool __cdecl do_encrypt(char const *,unsigned char *,int *,unsigned char *,unsigned char *)" (?do_encrypt@@YA_NPBDPAEPAH11@Z)
1>OpenSSLCryptoSample.obj : error LNK2019: unresolved external symbol _EVP_DecryptFinal_ex referenced in function "bool __cdecl do_decrypt(unsigned char const *,unsigned char *,int,unsigned char *,unsigned char *)" (?do_decrypt@@YA_NPBEPAEH11@Z)
1>OpenSSLCryptoSample.obj : error LNK2019: unresolved external symbol _EVP_DecryptUpdate referenced in function "bool __cdecl do_decrypt(unsigned char const *,unsigned char *,int,unsigned char *,unsigned char *)" (?do_decrypt@@YA_NPBEPAEH11@Z)
1>OpenSSLCryptoSample.obj : error LNK2019: unresolved external symbol _EVP_DecryptInit_ex referenced in function "bool __cdecl do_decrypt(unsigned char const *,unsigned char *,int,unsigned char *,unsigned char *)" (?do_decrypt@@YA_NPBEPAEH11@Z)
My VS2010 project is setup as follows.
C/C++ > General > Addition Include Directories
E:\libraries\boost_1_49_0 //as used in past projects
E:\usr\local\ssl\include //just installed
Linker > General > Addition Library Directories
E:\libraries\boost_1_49_0\stage\lib
E:\usr\local\ssl\lib
Linker > Input > Addition Directories
libeay32.lib
ssleay32.lib
Source file and header is just osslcrypto from an example.
