Issue after updating to the latest Catalyst Driver
MadMarc
Since I've updated my graphicscard drivers, the videocard outputs the wrong resolution, so there is a black frame around the desktop. This happens always when I start my computer and after about 30 seconds the screen seems to be properly recognized and the desktop is displayed normally.
Has anybody else the same problem? Any idea how I could fix it?
btw I have a SSD so there shouldn't be a problem with a slow bootdrive.
have you tried removing the driver completely and re-installing it yet? that woiuld be my 1st port of call
or just try rolling back the driver to see if it works fine
I have exactly the same problem, no idea why it does it but i might try downloading the 12.7 beta drivers, though i don't usually like using beta drivers as they can be quite buggy
The beta driver doesn't work for me, exactly the same problem, only when I uninstall the drivers completely this problem goes away
