°TheMadDutchDude°
Banned
Seeing you're under water.. OC the easy way. Push your volts up to 1.35v and save your BIOS settings. Then, reboot and go in to your BIOS again, and up your FSB by about 50 for the first time I'd say, then try boot in to Windows.. if it does, go back and add another 25 - 50 on, and so on and so forth.. though be careful as temperatures rise on a Quad quite quickly due to all the extra power they use. Keep going until you can't get a stable boot in to Windows, then knock off 10FSB and see if you got a stable boot and stable in Windows, then you're done
(the NOOBS way by the way
