Is this enough
blair
hi,
I have a OC 3930k and 2 OC HD 7970, currently im running a Ut60 360mm and a rs120 rads and the cpu gets quiet tostie at 86C on a hot day under prime! Will the following set up be enough and offer a temp drop?
1x Rasa Cpu block
2x EK HD7970 WB
1x D5 pump + bay res
1x UT60 Rad 360mm
1x UT60 Rad 240mm
to cool all of that fine the 360mm rad will have just pull with gentle typhoons 1850rpm, and the bottom rad the 240mm will have push apache fans or maybe push pull if i have enough.
I hope to not run the fans higher than 50% most of the time.
Also will the D5 be strong enough to move water round that lot? taking into account for angled fittings as well and a lot of hose to make it look neat.
Cheers
I think you should be fine. The D5 is a beast of a pump. Also those rads should be fine assuming they are 60mm thick
should be fine with that but let me ask you why are you running prime?? once ya use it to test stability thats it ur done no need to continually run it
is your current loop with/or without the GPUs in the loop?
if not, seriously you have an issue elsewhere. what vcore OC are you running? ambient?
are you running the fans now @ 50%?
the D5 is used in fatter systems so the flow wont be the issue.
airdeano
The cpu was being oC that why i was running prime95,
the gpu's and cpu are in the loop at the moment its at 1.336v for 4.6Ghz can go higher but i cant stress test longer past that cause temps go near 90C, playing BF3 the cpu gets to 68C and gpu's both around 57C thats with an ambient off about 20C
has this ever been on air-cooling?
b'cuz @ 1.35vcore that temp is dangerous, i'd expect this temp with 1.45-1.52vcore.
i'm not well versed in 2011 OC, but thats too hot and prime/IBT or LinX shouldnt cook
at that voltage, unless there isn't sufficeint cooling. which i think this is.. a UT240 should
be in the future or turn down the clock till then.
airdeano
