Is this build any good for my buget ?
Davidm97
Hey im just wondering if this is a good build ? For my budget of 500 - 600 Euro
  • Corsair Carbide 400R Mid-Tower Gaming Case
  • Corsair CM PSU 500W Builder Series
  • ASUS AMD 880G AM3 Motherboard
  • LG 22x DVD RW DRIVE
  • Corsair 1333 4GB 2x2 DDR3 Memory (RAM)
  • AMD Athlon II X2 250 3.00GHz
  • Artic Cooling Freezer 7 Pro Rev.2 CPU Cooler
  • Cooler Master 12cm SickleFlow Fans Blue LED x2
  • Western Digital Cavilier Blue 160GB Hard Drive
  • EVGA Nvidia GTS 450 (Video Card)
Is this a good build or a good choice of products ? Please leave your opinion.
- David Thanks
any build is a good build aslong as the componants do what you want them to do
what will this computers primary function be? gaming? multimedia? rendering? .....just internet use?
and then once we know what your going to be using it for, we can tweak your componant choises to better suit its use
as it stands, that would be a fine computer for internet usage & light gaming
or say for a family pc
or a HTPC
or a HTPC
I want to use it for gaming and maybe a bit of coding
for coding it will be fine
for gaming, you might need a bit more oomph in your GPU, maybe consider a ATi Radeon 5670 or similar? might be a tad more powerful for your budget?
I have a 5670 myself and its definitely a great card for it's price and power usage.
You might be able to get an AMD x3 core and unlock the 4th core as I've heard many people have done. Might be great for this.
You might also be able to find a decent Intel i5 bundle for a few hundred online. Try and search around mate.
