Is this an OK temp?
TalllPaul
As I have never had a graphics card before I am not sure if this temp is normal or not.
I have an R9 390 G1 Gaming Windforce and in my system I have 2 case fans, I downloaded MSI Afterburner to check the temps and it show 79ºC max whilst playing DiRT Rally with everything on Ultra.
If I see it correctly your max temp is 78-79°C ?
Nothing to worry about then, I've read that the card is designed to go as high as 94° and maintain that temp during high loads by adjusting its fan speed. High 70s are absolutely fine :)
That seems completely fine to me, i've seen a lot worse from the same core and windforce combination.
JR
The Windforce isn't the best cooler for those GPUs (but it does the job) so those temperatures seem completely normal given the situation.
I don't know about that. My Windforce 7970ghz keeps my card under 64C even when overclocked. Under 72C when run in CF. The key is lots of exhaust.
