is this a good gaming system for the price ?
doglad12
2nd Generation Intel® Core? i3 2120 3.3GHz Socket LGA1155 - Retail.
Novatech Prowler Midi Case V2
Gigabyte GA-H61M-S2PV Intel H61 (Socket 1155) Motherboard
Western Digital Caviar Blue 500GB 16MB Cache Hard Drive SATA 6Gb/s <8.9ms 7200rpm - OEM
Novatech 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit
Novatech PowerStation Gaming 400W Silent ATX2 Modular Power Supply
MSI AMD Radeon HD 6770 1024MB GDDR5
£344.88
i am building this rig for a friend he wants a really cheap system good enough to play games at medium hes not much of a graphics nut and the only demanding he will play is bf3
his budget is 350 so this is what i came up with.
i was just wondering if this is a good starter system for him.
BF3 will really struggle on that.
For a £350 budget I dont really know what else to suggest though. I couldnt do much better for £350 but at the same time I wouldnt even try to build a gaming system for that.
Only advice i could say would be go for an AMD, maybe phenom or llano build, save money on the cpu and then upgrade the graphics to a 7770 or a 6850/6870, but that may break the budget limit.
Also, the psu probably wouldnt be enough, and I wouldnt ever use an unbranded one. Other than look for second hand parts on ebay, I dont know what to suggest
i found a 6850 for 90 pounds ill use that instead of a 6770 ill use some of my own money to stretch the budget to 400 which is kinda hard to do since i am only 14
No, a 5770 is exactly the same chip as a 6770, just rebranded. the 6850 is a step up from that, but it wont make that much difference.
This would be my suggestion to you for this build
Best Value 777 T-BIRD-Blue Gaming Case (No PSU) £20.98
OEM-777-T-BIRD-BLUE
Corsair 600W Builder Series CX V2 ATX PSU £49.99
CMPSU-600CXV2UK
Gigabyte Z77-DS3H S1155 Intel Z77 DDR3 ATX £69.99
GA-Z77-DS3H
Intel Core i5-3450S S1155 2.8GHz 6MB £143.98
BX80637I53450S
Western Digital 500GB Caviar Blue 7200RPM 16MB SATA 6Gb/s £56.98
WD5000AAKX
Kingston 4GB (2x2GB) HyperX DDR3 1600MHz DIMM XMP X2 CL9 (Genesis Special Edition Grey) £21.99
KHX1600C9D3X2K2/4GX
Delivery costs £1.26
with discount of £10
Total £355.17
Dont forget that 3rd gen i5's give you HD2500 graphics which is good for low seting
OEM-777-T-BIRD-BLUE
CMPSU-600CXV2UK
GA-Z77-DS3H
BX80637I53450S
WD5000AAKX
KHX1600C9D3X2K2/4GX
Total £355.17
No way - you'd never get away with BF3 on intergrated graphics...
OEM-777-T-BIRD-BLUE
CMPSU-600CXV2UK
GA-Z77-DS3H
BX80637I53450S
WD5000AAKX
KHX1600C9D3X2K2/4GX
Total £355.17
Very good system, but his friend said that it needs to play battleifeld 3 at med settings
Yeah you'd struggle soooo much with BF3 with HD2500 graphics, i'd defo stick with the OP's build now he said he's gonna opt for a 6850
I'd be very surprise if you could build a system for £350 that could that said if you had a budget of £400 then you could add a Asus GeForce GT 630 810MHz 2GB PCI-Express HDMI to the build list i have posted
[media]http://youtu.be/mgIVgJaoJpk[/media]​
if hes not playing at 1080p then the 6770 should handle it well as my firends 6770 plays it at medium/ high at 780p
. i used to have an i3 before the 2500k and it handles bf3 fine
just change the psu and your fine
had a lot of friend have pc's die due to crappy psus.
Ah, good to see that I'm not the youngest member around here
But you should absolutely go for the 6850
