Is ADWCLEANER safe to use?
There are fake versions of ADWCLEANER which contain Malware and Viruses, if you're unsure just uninstall it, if it won't uninstall it's probably a fake, in which case you'll need Malwarebytes to get rid of it, and then look at CCLeaner from Piriform for doing drive cleaning.
Depends if she get a legitimate version. If you want to clean the PC then CCLeaner is probably the most reliable. Can also use Windows Disk Cleanup and use the advanced part to cleanup old windows updates that are no longer needed. I use both of these everyday to clean up what gets stored on the computer. You would be amazed at how much data gets onto the drives in one day..
No NBD, ADWCleaner specifically removes browser toolbars, search engines, etc that are spyware/malicious it doesn't clean bad registry.
https://toolslib.net/downloads/viewdownload/1-adwcleaner/ <---- if this is the program then it's the legit one!
I use it most of the times after a malwarebytes scan or when a browser has been highjacked by a toolbar! great tool! Absolutely recommend it!
