intel system
Hey i have a old intel system i wanna get going
its a 233mhz machine
wiv 32mb ram
no hdds (thats the problem)
When i put a HDD in it it wont recognize it and will say Insert Bootable Media
But it is a Manufactered one GATEWAY2000 System
so i was wondering do i need some software for the hdd to be reconized
thxs anyhelp would be helpfull
Thxs John
You probably just need to format the hard disk and install an operating system on it.
Try booting from a Windows CD and see if you can install Windows on the hard disk. :)
Wirelessly posted (Nextel. Done. |: BlackBerry7520/4.0.2 Profile/MIDP-2.0 Configuration/CLDC-1.1)
It won't recognize ur cd rom drive? If not then u either have a bad drive, the cable plugged in wrong, or a jumper set wrong on the back of the drive.
U won't be able to access a hard disk that hasn't been formatted with no bootable OS on it.
You then need to boot from CD-ROM and install an OS. It's going to continue to say "Insert Bootable Media" until a Master Boot Record is written to the drive from an OS install.
name='ComputersXp' said:
it wont even find the hard drive to install to ..and ive tried this ...and no luck cant u understand lol
U never said what wasn't finding the hard drive. Be more specific so we can HELP you. :rolleyes:
wiv 32mb ram
Thxs John
yess i did
yess i did
Ok that would be the BIOS not finding your hard drives...
What I'm talking about is the OS installer not finding your hard drives... Which is what we've been talking about in the last 10 posts. :rolleyes:
