Since installing my Maze 4 block (thats got less restriction that drainpipe), the flowrate in my system has gone thru the roof.
I've got an XSPC reservoir that does a good job of removing most of the bubbles, but the water passing thru the pipes is still slightly on the whiteish side - also, my rig sounds like a tap running into a sink.
Do you reakon i should just turn my D5 down, move to a T-Line setup or leave it as-is?
