FragTek
Ok guys, I'm looking to get a bit more oomph out of this computer I'm using. Mainly just to play WoW. Don't need anything too terribly extravagant, but something with a heck of a lot more horsepower than this FX5200.
What do you suggest? I believe the motherboard supports only 2x/4x AGP, which means a 4x/8x card wouldn't even fit the slot correct?
I don't remember which mobo it has off the top of my head, but it's an Intel board sporting the 845 chipset made for VPR Matrix.
Any suggestions?
Edit: After some research, it looks like the FX5200 is a 8x/4x card itself, so I should be golden... Any ideas? X800? X1650 Pro? What shall I do?
Any suggestions?
