IDNet ping problem
The official:
We've been investigating the ping spikes. It's been a curious one and what hasn't helped is that the issue has lacked consistency in that most customers seem to be unaffected. Mostly gamers (and not all of them for sure) seem to be affected for obvious reasons.
Though not yet confirmed, we suspect the route of the cause could be a faulty interface card. We're just waiting now for more data from some intensive debugging reports we've been running and then we should be in a better position to decide on the best solution. The ping spikes are almost certainly caused by the BGP scanner, though this in itself is not unusual and has proven to be a red herring, only the spikes are higher than would be expected which suggests they're the symptom of another issue. All configuration modifications to date have yielded little improvement which is leading us to the conclusion that we have a faulty interface card which may simply require replacing.
We're almost there but we want to be certain before we take the necessary steps to fix.
Any affected, sit tight for a couple of days.
