I had been working on this little project for a while but havent much time to spend now due to work.
It's a little program that will grab your bandwidth usage from the idnet website. It stores it in a ini file. I haevnt had time to make a gui to display it or anything. Perhaps someone who haas the time could make a objectdock thingy.
Anyways, just fill in your username password in the settings.ini file and then run update.ini, it should create a ini file called data.ini.
Please remember i'm still learning to program, so dont be suprised if you see any bugs.
update.exe
settings.ini
Hope it's of some use to someone!
O and post back to say how you got on with it, thanks!
EDIT: for some unknown reason, if the ini is corrupt, it should look like;
[IDnet]
Username=
Password=
update.exe
settings.ini
[IDnet]
Username=
Password=
