ideal temps
It all depends on your cooling setup...
On air decent temps hover around the 60*c mark.
On water they should be down in the 40's or so.
they stop working at -30 to -40*C so watch for that. :p
you want them as close to -30*C as possible. if ur card gets in the 75*C+ range you should get better cooling (IE nvsilencer)
I forgot the last time I phase changed my gpu ;) hehe
theres my 6800oc temp. :D idle
Looks pretty good mate - mine idls higher than that. Especially with the fault in the new drivers that give 10deg above the actual temperatures! :D
name='FragTek' said:
Quoting for super ban material :D
no i think hes just showin off his massive intellect (oh rite 4got peeps who resort to such insults are usually brain dead)
name='The_General' said:
Nothing to see here lets move on-PV
how would any one know shuch information , are you confusing your wet dream that you had last night with reality, XMS told u b4 no he is not gay and he has a wife and child , go away fantasise over some 1 else
Get em Joe! :D
have done on all the wankers posts (i think will just 2x check) cant let him have 1 unchecked (i wish i wer a mod id get his ip and then Mhahahaahahahahahaha)
If it's the same "The General" from OCN then he's also on here as "CHEMICAL" but he hasn't been around for awhile because I pimp smacked him in a couple of threads :D
i smaked him to look like a bitch in ALL his threads so far ; if u can prove hes is chemical then im sure XMS will love to ban him as well(PM XMS/some mod) <hint check out his other posts , well the follow ups b4 xms removes em in the more , which he should do)
Nope not the same as far as we know, just some little pin-dicked goat blowing twat with far too much time. I'm certain all the posts have been 'fixed' now, if you find one lemme know pls :)
PV
PV
:beerchug: Cheers PV!
