Dicehunter
Resident Newb
IBM has recently spent a whopping $3 billion dollars or £1,752,694,800 to be exact, On research and development to create the next generation of processors used 5 years from now.
Senior Vice President of IBM stated -
"We really do see the clock ticking on silicon, As we get into the 7 nanometer time frame, Things really begin to taper off".
As of this moment IBM are still making their products on the 22nm manufacturing process which will quickly be superseded by Intels up and coming 14nm Broadwell line up.
The alternative to silicon will be the very interesting material known as carbon nano tubes which you can read more about Here and a small picture below of what a carbon nano tube actually looks like, Remind anyone of Crysis ? ^_^
The other route IBM "May" take is "Nanophotonics" which instead of the traditional electronic current process it will use light, More info about that subject can be found Here.
Also thinking on the bleeding edge of technology IBM is considering "Quantum Computing", Find out more about that Here and "Neurosynaptic" chips, Find out more on that subject Here.
All of this could theoretically happen within the next 5 to 10 years IF the manufacturing process is perfected which is only a matter of time really.
Source - Here
