maniac
So after about 2 years of owning this cpu i finally decided to overclock it. It is an i7 950 (3.07 GHZ stock) and i just recently oc'd it to 4 ghz using settings i found on the internet and tweaked it a bit( changed multi from 23 to 24 so i could get lower bclk and eventually higher ram). i am currently stress testing using prime95 and so far max temps are 73,74,73,73 after 15 mins. do these settings look ok? is something too high or too low?
Ai Overclock Tuner.....................[Manual]
CPU Ratio Setting......................[24.0]
Intel(r) SpeedStep(tm) Tech............[Disabled]
BCLK Frequency.........................[167]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-1670MHz]
UCLK Frequency.........................[3340MHz]
QPI Link Data Rate.....................[6316MT/s]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.28750]
CPU PLL Voltage........................[1.88]
QPI/DRAM Core Voltage..................[1.35000]
IOH Voltage............................[1.24]
IOH PCIE Voltage.......................[Auto]
ICH Voltage............................[1.20]
ICH PCIE Voltage.......................[Auto]
DRAM Bus Voltage.......................[1.52]
DRAM DATA REF Voltage on CHA...........[Auto]
DRAM CTRL REF Voltage on CHA...........[Auto]
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto]
DRAM CTRL REF Voltage on CHC...........[Auto]
Load-Line Calibration..................[Enabled]
CPU Differential Amplitude.............[Auto]
CPU Clock Skew.........................[Delay 300ps]
CPU Spread Spectrum....................[Disabled]
IOH Clock Skew.........................[Delay 100ps]
PCIE Spread Spectrum...................[Disabled]
C1E Support............................[Disabled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled]
Intel(r) Virtualization Tech...........[Enabled]
CPU TM Function........................[Enabled]
Execute Disable Bit....................[Enabled]
Intel(r) HT Technology.................[Enabled]
Active Processor Cores.................[All]
A20M...................................[Disabled]
Intel(r) C-STATE Tech..................[Disabled
