Hi guys,
I am designing a new loop for my PC and wanted some input on potential changes. I do plan to watercool the GPUs in the not to distant future; so I am aware some components are more than a little overkill for just a CPU currecntly.
This is all going in a 900D, and I intend to add a second 480mm rad when I add the GPU blocks (2x 290s).
Anyway here is what I came up with atm:
XSPC RX480 Quad Fan Radiator V3 £104.99
EK Water Blocks EK-Supremacy EVO Elite Edition - Intel 2011 £84.95
PrimoChill 240mm AGB CTR Phase II for Laing D5 - Red £69.95
XSPC D5 Vario with Front Cover (1/2” barbs) £66.98
Mayhems Ultra Pure H2O 5Ltr £12.95
XSPC Hose Cutter (0-25mm) £6.95
Primochill Primoflex Advanced Tubing 16/11 - Red (3m) £17.97
Mayhems Fine Silver Kill Coil *4 £17.00
XSPC G1/4" to 1/2" Barb Fitting (Black Chrome) *10 £17.90
PrimoChill Black Steel Spring Clips - 7/16" *10 £7.00
I will recycle some SP-120s from my existing build.
At this stange I havent hunted around for price (for example its eaiser to get the distilled water locally but just want it on my list for safety.
Also I don't intend to use the clips; but I will probably buy a few just for safety.
I am not sure if I have enough tubing though; and is there any difference in cooling performance between the Evo Elite and Evo RED (as I think EVO RED may go better in my build; but I was recommended the Evo Elite) and can find very little information on this.
Thankies in advance
Thankies in advance
