I7 3770K 4.5Ghz OverClocking
PainKiller89
I have some questions and problems i am having regarding the voltage. I have been stable running intel burn test at 1.165 at 4.5 before doing all the changes in the bios. After doing the tweaks i had to push the voltage to 1.175 to run Intel extreme tuning utlity it ran fine for 5 hours. Then i started to run prime for 24 hours, for that i had to push the voltage to 1.190 to run it for 24 hours. Now i am having issues with games like bf3 in some maps it does a heavy lag. I have checked temps fine with cpu on load 45 and gpu's are fine as well. I am pretty much trying to figure out what is my stable voltage so i can do a offset voltage.
Try putting your PLL voltage to 1.5-1.6v and increase your LLC and Voltage Response Rate to fast. 1.2v at 4.5Ghz is pretty good IMO, I need 1.34v to get stable at 4.5Ghz...
Also, are you doing offset clocking or fixed voltage?
I have turned off PLL, also i have my voltage at 1.220 now for testing. i am using manual voltage. I also have my ram voltage to 1.5500. I do have power savings to off beside C1E, LLC is ultra high but power phase i set it to optimized instead of extreme.
