Depends on the motherboard and RAM you use. If it's low-profile RAM like Corsair Vengeance LP or any heatsink that doesn't really stick out over the DIMM, and you have a motherboard which' top heatsink isn't taller than your RAM, you should be able to fit an H100i in.
Otherwise you'll be limited to 120mm radiators.
