Just wanting a hand deciding on parts for my new build please. Going to be using the desktop for everything from gaming to downloading and watching hd movies on aswell. Really looking forward to a much needed upgrade.
Already got a nxt phantom gaming case with a i5 2500k cpu and a noctua nh d14 heat sink so basically just need a mobo, psu, ram and gpu and have £350 left to spend on them now.
I ideally want a z68 type mobo under £100 ideally that has an easy overclocking feature because ive not overclocked before but ive heard its easy on sandy bridge and Im going to try my best to get the cpu to 4.5 ghz (a lottery I know haha.) I also wanted to be able to use SLI or crossfire if i want to upgrade to two gpus in time.
Was looking at 8gb ripjaws x ram at 1600 but open to suggestions.
totally undecieded on the psu but wanted a modular supply ideally around 600w ideally and didn't want to spend too much.
For the graphics card any ideas with the remaining money I know the 560 ti has been highly recommended by a friend if i could afford it.
Any build suggestions or advice welcome , thank you.
